ASA 5505 with two ISP connections
May 5th, 2008
I have an ASA 5505 with two internet connections to two different ISPs, i followed the document "ASA/PIX 7.x: Redundant or Backup ISP Links
Configuration Example
Document ID: 70559" in cisco site and it succeeded to move from the main ISP connection to the Backup ISP due to the failure in the main ISP connection , but the problem is that the firewall doesn't return back to the main ISP connection when it comes up again
anybody can help??
Kureli Sankar Thu, 02/25/2010 - 17:04
  • Cisco Employee,
Yes, when a failover occurs it will log that in the syslogs and you can have these logs sent over as e-mail alerts.
Pls. refer here:
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/l2.html#wp1773126
hostname(config)# logging mail critical
hostname(config)# smtp-server pri-smtp-host sec-smtp-host
I had answered something similar on another thread which you can read here:
https://supportforums.cisco.com/thread/2004158;jsessionid=8637C493FE7EE5B5A436EAEEAABE9C37.node0?tstart=0
CSCtc16148
CSCsk65652
Check them both out. Neither of them is resolved yet.
Symptom:
Route Tracking may fail to fail back to the primary link/route when restored.
Conditions:
SLA monitor must configured along with ip verify reverse path on the tracked interface.
Workaround:
1. Remove ip verify reverse path off of the tracked interface
or
2. add a static route to the SLA target out the primary tracked interface.
Further Problem Description:
N/A
[Wrap text]  [Edit this enclosure]
Release-note: Added 09/23/2009 20:28:24 by kusankar
[Unwrap text]  [Edit this enclosure]
[Uwrap text]  [Edit this enclosure]
sla-mon-sh-tech: Added 09/23/2009 20:43:52 by kusankar
Can not view this .log file attachment inline, please click on the following link to view the attachment.
http://cdetsweb-prd.cisco.com/apps/dumpcr_att?identifier=CSCtc16148&title=sla-mon-sh-tech&ext=log&type=FILE
http://
[UnWrap text]  [Edit this enclosure]
[Wrap Text]  [Edit this enclosure]
-KS
