incoming call establish only if country code is used
May 5th, 2008
SETUP;
2801 WITH CME/CUE
With the below config;
- we are able to make outgoing calls
PROBLEMS;
- Incoming calls cannot be establish unless we use the prefix NNN which is the country code.
BELOW IS THE PARTIAL CONFIG RELEVANT ON THE PROBLEM;
voice translation-rule 1
rule 1 /^17517666/ /22/
rule 2 /^17517660/ /20/
rule 3 /^17517661/ /21/
voice translation-rule 2
rule 1 /^22$/ /NNN17517666/
rule 2 /^20$/ /NNN17517660/
rule 3 /^21$/ /NNN17517661/
voice translation-profile called
translate called 1
voice translation-profile calling
translate calling 2
interface BRI0/2/0
no ip address
shutdown
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
interface BRI0/2/1
no ip address
dial-peer voice 112 pots
translation-profile incoming called
destination-pattern .T
direct-inward-dial
port 0/2/0
dial-peer voice 113 pots
direct-inward-dial
port 0/2/1
Paolo Bevilacqua Mon, 05/05/2008 - 05:35
  • Hall of Fame,
    Founding Member
Where the translations are applied ?
Have you taken debug isdn q931 for a scussdul and unsuccesfull cal ?
Note, if you put the interfaces in trunk group, you will be able to use a single DP for both.
