4507 Restarts automaticaly
May 5th, 2008
Hi all,
I have one 4507R switch at distribution.since last 2-3 days it is getting restarted automatically.when I saw the logs nothing significant.
00:00:03: %C4K_REDUNDANCY-6-INIT: Initializing as ACTIVE supervisor
00:00:23: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:00:24: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-X4516-10GE S/N: JAB094000CT Hw: 2.1) is online
00:00:24: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 3 (WS-X4418-GB S/N: JAE0946Q3QU Hw: 1.2) is online
00:00:24: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 4 (WS-X4418-GB S/N: JAE1041D4L7 Hw: 1.3) is online
*May 3 10:48:22: %SYS-6-CLOCKUPDATE: System clock has been updated from 07:48:22 UTC Sat May 3 2008 to 10:48:22 DST Sat May 3 2008, configured from console by console.
*May 3 10:48:24: %SYS-5-CONFIG_I: Configured from memory by console
*May 3 10:48:24: %SYS-5-RESTART: System restarted --
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9K91S-M), Version 12.2(25)EWA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 23-Sep-05 13:24 by ssearch
*May 3 10:48:24: %SNMP-5-COLDSTART: SNMP agent on host BD-COMMON-4507-1 is undergoing a cold start
It says the clock is updated from console by console.Whereas nobody did anything.Once the clock is updated it restarts.
Another problem is when it restarts each time the uplinks connected to the access switches goes down & it doesnt come up. By changing to another port only the link comes up.
Can anybody advise what could be the reason ? And why the uplinks go down after each restart.
Thanks in Advance
Sachi
sabgato130 Mon, 05/05/2008 - 07:57
If it does automatically reboot by itself and its not power/electrical or environment related then,
1. how old is the catalyst in production-you might need check your CMOS or first do a thorough hardware maintenance.By this it might mean sure signs of hardware failure.
2. i might not have too much explanation on the uplink cause I am assuming everything was working prior to your troubles albeit seamlessly.It still could be pointig to an hardware degradation that needs detecting.
regards,
Shams
sachidananda panda Mon, 05/05/2008 - 08:07
Hi Shams,
Thanks for response.
The switch is only 4 years old. Do u think u need a hardware maintance.If so how recomend to do it. Can u pls explain me in details.
Dont you think its any IOS issue.
Thanks again in advance
Sachi
sabgato130 Mon, 05/05/2008 - 08:54
1. yes that is also another possible option.
judging by the age it should not be developing such problems so early.You try re-imaging the device possibly if there is an upgrade to which it conforms with in terms of basic flash and DRAM requirements.maybe just download a fresh one or if u have another 45xx dat can be used u can tftp from there or replace as a whole.
2.By h/w maintenance- you might hv to consider a minimal downtime as this needs to be done when the device is powered down (best practice).
You would need a blower or a vacuum to clear away all clogs(if any) of dust,etc.
I wouldn't recommend opening d device as your warranty/support might be voided by cisco.
3.Thirdly, if problems persist..open up a TAC case...maybe you might be looking at getting a stop gap issue from cisco in earnest.
regards
cisco_lad2004 Mon, 05/05/2008 - 10:40
  • Gold, 750 points or more
use "sh platform crashdump" to see if there are more info on the reboot. it might be a crash due to a SUP or IOS.
most of my 4510R when crashed, SUP was to blame.
in few cases, I noticed some commands crashed the box. this was resolved by uploading a newer IOS with bug fixes.
Sam
sachidananda panda Mon, 05/05/2008 - 12:56
Actually I got a feild notice which says this is bcoz of the SDRAM degradation.A specific range of hardware verson & S/R no. is affected by this & sup coming under this.
Solution is to replace the SDRAM & upgrade the image (existing(12.2 (25) EWA-4) higher than 12.2(31) SGA
http://www.cisco.com/en/US/partner/ts/fn/620/fn62479.html
Thanks guys for ur quick response
Sachi
