802.1x guest vlan monitoring
May 5th, 2008
Is it possible to get a 3560 or 3750 to send a SNMP trap if a port is placed in the guest vlan for 802.1x? I can pull the information via Solarwinds using the OID 1.3.6.1.4.9.9.220.1.1.1.4, but so far have been unable to figure out how to get the switch to send that information. Also, if there is a way to get the switches to send a trap if a port enters a particular vlan, that would work as well.
didyap Fri, 05/09/2008 - 07:58
  • Silver, 250 points or more
No there is no any option to send a SNMP trap if a port is placed in the guest vlan for 802.1x or any port enters
a particular vlan.
