VPN second peer
May 5th, 2008
If I want to set second peer in the ipsec-isakmp, anyone know what is the minimum IOS version
crypto map abc 1 ipsec-isakmp
set peer 10.1.1.1
set peer 10.2.2.2
Overall Rating: 3 (1 ratings)
Richard Burts Mon, 05/05/2008 - 07:02
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jack
I am pretty sure that I have been putting 2 set peers into an instance of a crypto map since at least 12.3 and I suspect that it goes further back than that. Is there a particular version that you are interested in? It may be easier to figure out support in a particular version than it is to track how far back the feature is supported?
Rick
Rick Morris Tue, 05/06/2008 - 05:25
  • Silver, 250 points or more
Yes, Rick, I do not know specifically, but I have done this with 12.x code. If there is a concern, download the latest IOS.
