Excessive UDP teardown
May 5th, 2008
Hello can a pix generate a UDP teardown without a subsequent UDP setup. I am seeing excessive teardown on the network. Trying to find out the cause.
smahbub Fri, 05/09/2008 - 06:05
Can you provide the error messages that you are observing on the device as it will be easier to trace the reason for the udp teardown using the error message. With the error messages you can easily find the reason for the teardown.
