paolo bevilacqua Mon, 05/05/2008 - 09:24
  • Hall of Fame,
    Founding Member
You can do a configuration like that if you want. What is the purpose ?
miskoolak Mon, 05/05/2008 - 10:29
hi.
I have one e1 from pbx.i want to channelize my e1 into 30 timeslots.snd use 30 fxs and map each fxs to one timeslot. so these 30 channels can connect each other.
paolo bevilacqua Mon, 05/05/2008 - 12:10
  • Hall of Fame,
    Founding Member
Yes, you can do something that. There is no need to map fixed ports, the pbx doesn't really work like that, it works with dialed numbers numbers.
However FXS ports on routers are expensive considering the basic service given, so you can consider IP phones instead, with the CCME feature on the router.
