05-05-2008 09:15 AM - edited 03-03-2019 09:49 PM
Need advise/help please
Ip 70.x.x.x = Local Users / Backup Email ip
Ip 69.x.x.x = Email / Local users Backup ip
Everything seems to be working almost ok. The problem I am having is that the router defaults to the 70.x.x.x ip for Email. Here is part of the config file.
I think the problem is with my lst command line.
track timer interface 5
track 10 rtr 1 reachability
delay down 15 up 10
track 20 rtr 2 reachability
delay down 15 up 10
ip route 0.0.0.0 0.0.0.0 FastEthernet0 70.x.x.x track 10
ip route 0.0.0.0 0.0.0.0 FastEthernet1 69.x.x.x 200 track 20
ip nat inside source route-map cable-nat interface FastEthernet0 overload
ip nat inside source route-map dsl-nat interface FastEthernet1 overload
ip nat inside source static tcp 192.168.0.15 25 69.x.x.x 25 route-map exchange extendable
ip nat inside source static tcp 192.168.0.15 25 70.x.x.x 25 route-map exchange extendable
access-list 111 permit tcp host 192.168.0.15 any eq smtp
route-map exchange permit 10
match ip address 111
set ip next-hop verify-availability 69.x.x.x 1 track 20
If i add this line would it be correct?
route-map exchange permit 20
set ip next-hop verify-availability 70.x.x.x 2 track 10
OR
Thank you!
05-05-2008 11:18 AM
Hi Stathis,
I'm not sure what is exactly your problem.But I would use the command as follows:
The router will send SMTP traffics out of the fastethernet1 interface if it is UP. If not then send to the fastethernet0 interface for backing up. ##If It's up as well ;-)
Hopes this helps
Thot
05-05-2008 12:16 PM
Thx Thot
The problem is that when I receive email it defaults to fastethernet0 70.x.x.x and not the 69.x.x.x in fact port 25 on the 69.x.x.x is closed. fastethernet0 70.x.x.x port 25 works fine.
If i simulate a fail for 70.x.x.x then 69.x.x.x port 25 works fine.
Somehow i have to reverse it if its possible.
Thank you
05-05-2008 12:27 PM
Hi Stathis,
Please correct me if I'm wrong. You meant that you receive the e-mails from 70.x.x.x.So what's going on?
I want to send an email to you.I have to solve your MX-Record first. I meant your domain.ISP tells me hey! sathis@abcd.com please go to 70.x.x.x.
Please tell me what's your exact public ip address(high priority) using for SMTP traffics(Inbound!).
Is that your problems? if so,ISP will be involved I guess!
Hopes this helps
Thot
05-05-2008 12:37 PM
Sorry Thot let me try again. The router is not live yet i plug it in after work hours to test it.
70.x.x.x Fa0 = Local users internet - Backup for exchange
69.x.x.x Fa1 = Exchange - Backup for Local Users
With my current configuration when i try to telnet to port 25 or access port 25 on the 69.x.x.x Fa1 i get denied BUT 70.x.x.x Fa0 works fine.
If I simulate fail on 70.x.x.x then 69.x.x.x works fine which is very cool but its reversed. I want 69.x.x.x as first email ip and 70.x.x.x as backup.
The isp is set to sent to 69.x.x.x first and if it fails it will try 70.x.x.x
Thank you
05-05-2008 12:50 PM
Hi Stathis,
I think you need to use a "sh ip nat trans" command and see what happens when you telnet tcp/25 on the 69.x.x.x address. Is there an interesting NAT entry on it?
Using a "netstat -an" command on the server(192.168.0.15).Is there any connections from the outside using TCP/25? Is the status "established" or "TimeOut" or nothing?
Is there any devices between the router and the server Aka a firewall?
Hopes this helps
Thot
05-05-2008 01:59 PM
Thx Thot
I will check but i believe the router somehow is blocking port 25 as it thinks the 69.x.x.x is the backup ip.
Its allowing port 25 on the 70.x.x.x to receive incoming email if I unplug it its allowing port 25 on 69.x.x.x to receive email.
I will open a support call to see if they can help me.
Thx again Thot!
