ISDN BRI and CCM issue
May 5th, 2008
HI all,
recently i tried to configure an ISDN connection with CallManager and it works fine but i'm stuck in something and thanks for ur previous posts by the way
I have a range of number from my SP like:
from 555501 to 555509 and i want that a predefined IP Phones like extension 4000 to use a specific PSTN number for inbound and outband Call and with an anology from the FXO conf i set up the:
Destination-pattern 9T for outband call
and
Connection plar opx 4000 for the inband
BUT with the BRI how it can be done?
Thanks in advance for all
gogasca Mon, 05/05/2008 - 20:46
  • Green, 3000 points or more
You can configure the BRI either as MGCP or H323
If H323 then configure a dial-peer pots with direct inward dial then a voip to fwd the number directly to ccm
If MGCP Just configure proper CSS and incoming settings for Voice Port
Seifeddine-Tlili Mon, 05/05/2008 - 22:50
thanks for your reply but if the user want to use a specific number as his personnel PSTN number i mean for example if DN 4000 want only to use the PSTN number 555022 as the outband call ?
