network teaming
May 5th, 2008
Hi, I would like to setup network teaming on my servers, can anyone tell me what has to be done on a switch or the ports. All I can think of is that the ports should be on the same vlan. Thanks
Mark Yeates Mon, 05/05/2008 - 15:50
I'm not sure what kind of equipment you have. Here is an example of a port channel to a team NIC.
interface Port-channel2
switchport
switchport access vlan 31
interface GigabitEthernet5/29
description server link 1
speed 1000
duplex full
no cdp enable
channel-group 2 mode on
spanning-tree portfast
interface GigabitEthernet5/30
description server link 2
speed 1000
duplex full
no cdp enable
l.mourits Wed, 05/07/2008 - 00:30
Your switch config and teaming setup have to be in sync, that is where this boils down to.
If you set your teaming config for channeling, see the reply on how to configure the port channel. This config is typically used when the two teaming interfaces connect to the same switch or switch stack.
If you set it for fault tolerance, there is no need to configure a port channel on your switch, as STP will block one port. This config is typically used when teaming interfaces connect to different/redundant switches.
Configs not in sync may cause issues and your teaming to fail.
HTH,
Leo
MUHAMMAD SHAHEEN Wed, 05/07/2008 - 09:14
A while back someone asked the same question. Please see this link. On most servers it is the teaming software on the server performs teaming of 2 LAN interfaces. On the switch ports make sure to have the same VLANs if you have vlans in place. And let us know if you need any further help.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40.2cbec306/4#selected_message
Shaheen
