CRC errors on Ethernet port
this is my Cisco 2600 Ethernet port:
Ethernet0/0 is up, line protocol is up
Hardware is AmdP2, address is 0005.3286.7ca0 (bia 0005.3286.7ca0)
Description: LAN on VLAN42
Internet address is 192.168.42.3/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 40 drops
5 minute input rate 7000 bits/sec, 4 packets/sec
5 minute output rate 6000 bits/sec, 5 packets/sec
54427244 packets input, 1856974710 bytes, 0 no buffer
Received 8074229 broadcasts, 0 runts, 0 giants, 0 throttles
46267 input errors, 46267 CRC, 42567 frame, 0 overrun, 0 ignored
46283675 packets output, 877298486 bytes, 0 underruns(0/0/0)
40 output errors, 0 collisions, 3 interface resets
40 lost carrier, 0 no carrier
interface Ethernet0/0
description LAN on VLAN42
ip address 192.168.42.3 255.255.255.0
full-duplex
end
this is the other end - Cisco 3560G:
interface GigabitEthernet0/5
switchport access vlan 42
switchport mode access
duplex full
spanning-tree portfast
end
GigabitEthernet0/5 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0017.e040.4185 (bia 0017.e040.4185)
Full-duplex, 10Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:52, output 00:00:01, output hang never
Output queue: 0/40 (size/max)
5 minute input rate 7000 bits/sec, 6 packets/sec
5 minute output rate 11000 bits/sec, 11 packets/sec
44681598 packets input, 969282128 bytes, 0 no buffer
Received 302392 broadcasts (0 multicast)
0 watchdog, 296938 multicast, 0 pause input
130929196 packets output, 432025420 bytes, 0 underruns
why do I get CRC errors?
do I have to set the 3560 to 10mb?
thotsaphon Mon, 05/05/2008 - 11:27
Hi Ofir,
Did you already check/change the cable first?
For testing:
Can you hard-code the switch and the router to be 10Mb/Full Duplex?
Hopes this helps
Thot
didn't replace the cable - will do after hours today
about hard-coding 10Mb/Full, both have Full Duplex coded. the reason I didn't code 10Mb on the 3560 is that the 2600 does not have the option to encode speed. I assume it has 10Mb coded by default.
I'll try coding the 3560 to 10Mb (though the errors only show on the 2600)
thanks (and I'll be back with an update)
burleyman Mon, 05/05/2008 - 11:44
CRC errors ussally indicated a physcial issue. I would clear the counters and see if they are still going up as they could be old errors because the counters have never been cleared. If they continue to increase I would replace the cable to start with and then clear the counters again and see if they continue.
Hope this helps,
Burleyman
burleyman Tue, 05/06/2008 - 04:06
I would just keep monitoring the ports. If the errors don't return they may have been some old errors from when the switch was deployed. You could still swap out the cable but if the errors are not coming back you could hold off. Again, CRC errors usually point to a physical problem, i.e. bad cable, bad port, but could still increment if there were allot of collisions due to a duplex mismatch but there were 0 Collisions so I don't think that was it.
Hope that helps,
Burleyman
burleyman Tue, 05/06/2008 - 04:08
Also, forgot one thing. If you had a speed/duplex issue the counters would continue to climb after you cleared the interface counters.
Burleyman
lamav Mon, 05/05/2008 - 11:53
Hi:
Swap the ethernet cables out with known good ones.
The try using new ports.
CRC errors usually indicate bad hardware.
Victor
glen.grant Tue, 05/06/2008 - 03:31
I know on some of the old 2600's they would not do full duplex even though the duplex command was there so if the 2600 is half duplex and the 3560 is set as full duplex you have a speed duplex mismatch and thats why you are seeing crc's and errors .
