isr1800 L2L ipsec tunnel with Netscreen ISG2000
May 5th, 2008
Hi all!
I have a problem setting up an ipsec tunnel between a 1811 ISR router and Netscreen ISG2000 device.
After the successfully completed Phase1 appears an error which i cannot understand where it is come from.
*May 5 23:27:25.694 EET: ISAKMP:(2921):Need config/address
*May 5 23:27:25.694 EET: ISAKMP: set new node -745013984 to CONF_ADDR
*May 5 23:27:25.694 EET: ISAKMP:(2921):No IP address pool defined for ISAKMP!
*May 5 23:27:25.694 EET: ISAKMP:(2921):peer does not do paranoid keepalives.
*May 5 23:27:25.694 EET: ISAKMP:(2921):deleting SA reason "Fail to allocate ip address" state (R) CONF_ADDR (peer zz.yy.xx.vv)
*May 5 23:27:25.694 EET: ISAKMP:(2921):deleting node -745013984 error FALSE reason "No Error"
I have tried with different isakmp/ipsec parameters I also changed the IOS but nothing changed. Did anybody have experience with this error message?
Netscreen: ScreenOS5.4
ISR1811: 12.4(15)T4
oszkari Sat, 05/17/2008 - 06:26
Problem solved.
There is a well known incompatibility issue with third-party ipsec clients (problem description:CSCsh20354)
I removed the easy vpn server from the cisco and everything started to work.
But I can't figure out why the juniper equipment was treated like an easy vpn-client.
