05-05-2008 12:53 PM
When I set up the File Servers for my core and edge WAE's I understand that this will provide CIFS acceleration - in addition to the TFO/DRE/LZ features. Does this CIFS acceleration only provide benefits for file shares - or would it also provide some benefit for the logon process w/ roaming profiles?
05-05-2008 01:03 PM
Michael,
If your roaming profiles are on a server that isn't using SMB Signing, then the CIFS/WAFS adapter can provide CIFS acceleration. However, usually the profiles reside on a Domain Controller, which has SMB Signing turned on by default, and as a result, most of the profile traffic, even though it's CIFS, gets punted outside the CIFS adapter.
Hope that helps,
Dan
05-08-2008 04:54 AM
In most cases I've seen the DC's store the configuration info (location) of the roaming profiles and then the actual user profiles are stored on a file server. If this is the case would CIFS acceleration 'kick in' during the logon process?
Thanks for the follow up.
05-08-2008 06:52 AM
Correct, as long as the file server redirected to does not have SMB Signing turned on and is within range (25 ms by default) of the Core WAE(s).
Hope that helps,
Dan
