Mobility Manager Configuration Guide for CUCM 6.X
May 5th, 2008
Can someone please point me in the right direction.
I am looking for the configuration guide for Mobility Manager for CUCM6
I am having issues when calling into voice access from the mobile phone, authenicating OK, then pressing "1" to dial an extension number. The call clears down as soon as the # is entered after the extension number.
Can someone please help
Steve
Overall Rating: 5 (1 ratings)
steve-parrish Mon, 02/09/2009 - 01:39
check your CSS on the Remote Destination
also make sure your codec's negotiated ok
shingphing_2 Mon, 02/09/2009 - 01:52
Steve,
I did not configure any css and partition.mobile connect works fine.
steve-parrish Mon, 02/09/2009 - 01:55
I found MVA uses the CSS on the RD to allow calls through option "1", (not the reroute CSS)
shingphing_2 Mon, 02/09/2009 - 01:59
thks .but all my css and partition are set to "none".do you thk these will affect the option "1" routing.I have no problem calling out from phones.Call options 1 call internal extension?
steve-parrish Mon, 02/09/2009 - 02:04
Try using DNA with the RD Extension number and ensure you can make all necessary call types
shingphing_2 Mon, 02/09/2009 - 02:13
thks .In fact i have a ip communicator with the RD extension which have no problems making outside calls.
Have a pleasant day !!
