05-05-2008 02:58 PM - edited 03-18-2019 08:53 PM
I need to know if it is possible to have the exchange server 2003 running on the same unity 5.0 server for Unified Messaging configuration. do i need to storage the exceeded data on a storage server?
how can i do that?
I know this is an unusual configuration unfortunately my costumer though microsoft Outlook and Microsoft Exchange is the same, and now we need to UM works without Exchange 2003 parther server.
thanks
Miguel
Solved! Go to Solution.
05-05-2008 05:38 PM
not possible and not supported
Exchange Requirements-Message Store
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/requirements/50cusysreq.html#wp472166
UM requires Exchange in a separate server
javalenc
if this helps, please rate
05-05-2008 05:38 PM
javalenc
05-06-2008 10:41 AM
Thank you for your comment, i think that my costumer needs to set up en Exchenage Server very quick!
Miguel
