How do I configure a CM that will have ATAs and IP phones other than Cisco? for instance a CM with 700 non cisco extensions and one Cisco Gateway with two E1 and one non Cisco Gateway with 2 E1s.
Other than Cisco IP Phones you can use Avaya IP Phones with CCM. Those will work fine.
Rate the solution if it works.
Thanks.
