ASA 5505 Internet Failover
May 5th, 2008
We have an ASA 5505 with Security Plus Bundle. I need documentation on how to setup the ASA to allow me to use my T1 Internet connection (which is currently functioning) as my primary Intenet connection and my secondary DSL line as a backup or failover Internet connection.
I have attahced my current configuration on which the failover is NOT working.
The expected result is that if the primary T1 internet fails, then the ASA detects the loss and switches over to use the DSL line to provide Internet and when the T1 becomes active again it switches back.
JORGE RODRIGUEZ Mon, 05/05/2008 - 17:04
Your config looks fine , see the end of this doc for troubleshooting steps to determined wat could be the problem, you may need to do some debuging to pin point where the failure is occuring.
I would first check the following to rule out the backup isp connection is not bad.
Step 1- Make sure the backup ISP link is functional, plug in a labtop and try connecting to internet. If the backup ISP connection is good then you will have to do the troubloeshooting provided in link document end of it.
Try checing the above
see troubleshooting section
show running-config sla monitor
show sla monitor configuration
show sla monitor operational-state
debug sla monitor trace
debug sla monitor error
