WiSM - Interface Vlan Overlapping within AP Group
May 5th, 2008
Hi there,
Need help on this. Wism that deployed on the network had found issue in interface vlan overlapping. Had configured the vlan interface and assign to a group. The group had been define on specific lwapp APs. However user that manage to associate with the particular AP had used the different group that not specify to that APs. It had been using the group that been specify to other APs that located at different location.
Any ideas on this? Is this internal bugs? I had checked with the bugs listed in Cisco software. But not mentioned about this. Fyi, we are running on software version 4.1.171.0. and also we are operates almost of 80 Aps under 40 interface vlan assign to the groups.
bwilmoth Fri, 05/09/2008 - 06:19
Could you provide the details of the wism configuration?
Trending Topics - Security & Network
