voice gateway configuration issue
Answered Question
May 5th, 2008
I'm using a CCM 4.1 and a Cisco 2801 (adv ip services) with PVDM-64 and VWIC-2MFT-E1.
When i try to configure pri-group timeslots using the commands : pri-group timeslots 1-31 service mgcp I have the following error message :
%Insufficient resources to create pri-group - it has been removed
Could please see for me what could be the problem ?
P.S : the 2801 router is not a bundle voice, i have just added the PVDM card.
Correct Answer by Rob Huffman about 8 years 11 months ago
Hi Dominique,
I have seen this in a few instances where the VWIC is installed in slot 0 instead of slot 1. (only WIC modules are supported in slot 0.
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Mon, 05/05/2008 - 17:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Dominique,
Hope this helps!
Rob
dom.a Mon, 05/05/2008 - 17:16
Ok, but i think it is not the case for me. See the attached file for the 'sh diag' command response. it indicates that PVDM2-64 is installed on PVDM slot 1.
have a look on this attachment pls.
Jaime Valencia Mon, 05/05/2008 - 17:32
  • Cisco Employee,
  • Hall of Fame,
    2011
Rob never mentioned the PVDM2 module on the wrong slot, but the VWIC in slot 0 when it should be in slot 1.
see what you have:
VIC Slot 0:
E1 (2 port) Multi-Flex Trunk WAN daughter card
javalenc
if this helps, please rate
dom.a Mon, 05/05/2008 - 17:45
ok ok , excuse me. So I need to replace the VWIC card on slot 1 instead of slot 0.
Let me try it...
Thanks Rob & Javalenc.
Rob Huffman Mon, 05/05/2008 - 17:40
  • Hall of Fame,
    Founding Member
Hi Dominique,
I think this clip shows the issue;
VIC Slot 0:
Hardware revision 1.0 Board revision D0
Serial number 34010819 Part number 800-04479-03
FRU Part Number VWIC-2MFT-E1=
It does show a VWIC in VIC Slot 0 which is not supported on a 2801. Can you try moving the VWIC-2MFT-E1.
Hope this helps!
Rob
