Background image change 7961/70 - ccm6.0
May 5th, 2008
  • Bronze, 100 points or more
Hi all,
I am trying to change the background image of ip phones 7961 and 7970. i followed the procccedure given in docs of respective phone.i resized image for each phone type and list.xml file. still not working. My list.xml file for 7970 is attached here. What i am missing.
Thanks in advance.
Overall Rating: 5 (1 ratings)
neil.woolloff Tue, 05/06/2008 - 02:57
Try the following which is based on the Cisco documentation, but makes it slightly cleare; well I'm hoping...
Cisco Unified IP Phone 7970G and 7971G-GE Administration Guide for Cisco Unified CallManager 5.x & 6.x (SCCP and SIP)
Customizing the Cisco Unified IP Phone
Part1
Create a List.xml
example;
FTP:Desktops/320x212x12/TN-Filename.png" URL="TFTP:Desktops/320x212x12/Filename.png"/>
create images to be used
•Full size image-320 pixels (width) X 212 pixels (height)
•Thumbnail image-80 pixels (width) X 53 pixels (height)
•Color palette-Includes up to 12-bit color (4096 colors). You can use more than 12-bit color, but the phone will reduce the color palette to12-bit before displaying the image. For best results, reduce the color palette of an image to 12-bit when you create a PNG file.
for ref use
TN-filename.png for the thumbnail image
filename.png for the full size image
Part2
Logon to CCMAdmin
Select OS Administration
Select Software Upgrades
Select Upload TFTP Server File
Enter the Sub Directory as /Desktops/320x212x12 - EXACTLY AS SHOWN
Browse for the List.xml & image files
Click Upload
Restart the TFTP Service;
Select Cisco Unified CallManager Serviceability
Select Tools
Select Control Center - Feature Services
Place radio buttin against Cisco tftp
Click Restart
Part3
At the phone;
Select Settings
Select User Preferences
Select Background Images
Select your images
Click Save
hardiklodhia Tue, 05/06/2008 - 06:11
Hi neil,
I followed the same steps mentioned above. though i was not able to make it.After all i found the mistake.In List.xml,which i just copied it from cisco doc with my filenames. but now i replaced ” with " and its working...
