AAA for Cat OS switch
Answered Question
May 5th, 2008
I having a problem on how to create a Shell command authorization for my Cat OS switches. My ACS version is 3.3
Appreciate you help
Jong
Correct Answer by Jagdeep Gambhir about 8 years 9 months ago
Jong,
Here are the CAT OS commands,
Set Based -
Console> (enable) set tacacs server [IP] [primary]
set tacacs key [key]
set tacacs attempts [number] (optional)
set localuser user [user] password [password] privilege 15
set authentication login local enable
set authentication login tacacs enable [all | console | http | telnet] [primary]
set authorization exec enable tacacs+ [deny | none] [console | telnet | both]
set authorization commands enable [config | all] tacacs+ [deny | none] [console |
telnet | both]
Here is the link for setting up command authorization , this example is for IOS but it you understand the concept, you should be able to set it up on CAT OS.
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Tue, 05/06/2008 - 04:59
Jong,
Set Based -
telnet | both]
~JG
jong_r0602 Tue, 05/06/2008 - 18:36
HI JG,
Wow! It works also in my CAT OS switches.
Thanks a alot,
Jong
