ASA 5520 with SSM
May 6th, 2008
Hi all,
I have ASA 5520 with CSC-SSM modul. And, i am intrested in, What IP address and Gateway have i to assign to SSM module. I know, IP which will be assign SSM module have to reach internet for Trend Micro for updates. I just need to assign inside interface any IP address and gateway ??? Need UR advice :)))
tnx in advance
tj.mitchell Wed, 05/07/2008 - 08:16
  • Bronze, 100 points or more
Typically, this IP Address is on the internal network and used for management. I usually give it an address from a management network with associated gateway to allow for access to the internet.
batumibatumi Wed, 05/07/2008 - 22:52
Great tnx mitchell , U R only person who respond me :)))
mitchell, to ask U more detail: i gave SSM modul IP address from managment network, but gateway must be outside or inside intrface IP ... ? for example, IP address - 192.168.1.100, Gateway Inside interface IP 10.x.x.x or Outside interface IP 77.x.x.x
Sorry for my poor English. I hope U understand what i said :))) tnx, in advance :)))
batumibatumi Wed, 05/07/2008 - 23:36
tnx, but what will happen if i'll assign IP address of inside interface, which could be reach to internet... ??? :)))
Its very kind from UR side to help me to findout unknow things for me.
leo_zidane Thu, 05/08/2008 - 04:23
inside interface should be used to go into your internal network.
If you say internet to be inside, the routing is like looping around.
batumibatumi Thu, 05/08/2008 - 06:06
But, i'm going to use inside network users to have access to internet (using PAT) ... my question: if i'll assgn IP address SSM modul 10.0.0.100 and its gateway will be Outside interface IP ... is it OK ???
tj.mitchell Thu, 05/08/2008 - 09:54
Give it an internal IP Address and gateway for your network. So long as this network has access to the internet you'll be fine.
Example:
IP Address 10.0.0.100 /24
Gateway 10.0.0.1
