upgrade Supervisor Engine on cat6500
jim-bovis
I want to upgade the old Supervisor Engine 1 on a cat6500 switch with a Supervisor Engine 32.
Does it works, or I have compatibility problems?
Martin Parry
Level 3
Level 3
The sup32 is compatible with all 6500 series chassis, however you will need to ensure that you have a FAN-TRAY-2 or an E-FAN, and at least 2500W PSU's.
Martin
ankbhasi
Hi Jim,
You are good to go. This link will clear all your compatibility doubts
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5972/prod_qas0900aecd80350bfc.html
Ankur
*Pls rate all helpfull post
Thanks !!
