T1 e&m - 2 way problems. Post in wrong forum Sorry
May 6th, 2008
I am having problems with a T1 circuit (ESF, B8ZS and E&M Winkstart) and CallManager 4.2.
controller T1 1/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1-24 type e&m-wink-start
This is terminating on a 2621XM with a NM-HDV.
I can successfully make inbound and outbound calls depending on having the port line in on the pots dial-peer.
If I have the port line in on the pots dial-peer, I can make outbound calls but inbound calls fail. On debug of voice vtdp inout I see there is no Called number. Debug attached.
voice-port 1/0:0
translate called 1
bearer-cap Speech
dial-peer voice 9 pots
tone ringback alert-no-PI
destination-pattern 9.T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
progress_ind disconnect enable 8
fax rate disable
direct-inward-dial
forward-digits 11
port 1/0:0
If I take out the port line from the pots dial-peer inbound calls work and the deb shows the called number. But obviously the outbound doesn't work.
I dont know if the call is failing before it sends the DNIS or DNIS is the problem I dont know enough about e&m.
voice-port 1/0:0
translate called 1
bearer-cap Speech
fax rate disable
direct-inward-dial
forward-digits 11
This is the voip dial-peer
dial-peer voice 101 voip
preference 1
destination-pattern 23T
modem passthrough nse codec g711ulaw
voice-class codec 1
session target ipv4:10.3.1.14
incoming called-number .
dtmf-relay h245-alphanumeric
fax rate disable
no vad
An ideas greatly appreciated.
deb vpm....
*Jun 11 09:45:14.498: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0xC timestam
p=23669 systime=13390097
*Jun 11 09:45:14.498: htsp_process_event: [1/0:0(1), EM_ONHOOK, E_DSP_SIG_1100]e
m_onhook_offhook htsp_setup_ind
*Jun 11 09:45:14.502: [1/0:0(1)] get_local_station_id calling num= calling name=
calling time=06/11 09:45 orig called=
*Jun 11 09:45:14.502: TGRM: reg_invoke_tgrm_accept_call(1, TGRM_CALL_VOICE, TGRM
_DIRECTION_IN, 1, 0, 0, 0)
*Jun 11 09:45:14.502: TGRM: Calling vtsp_tsp_call_setup_ind().
*Jun 11 09:45:14.502: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x840BFDFC,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_PORT;
Result=Success(0) after DP_MATCH_PORT; Incoming Dial-peer=9
*Jun 11 09:45:14.506: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:[email protected]
*Jun 11 09:45:14.506: TGRM: reg_invoke_tgrm_call_update(1, 0, 0, 0, 1, TGRM_CALL
_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
*Jun 11 09:45:14.506: htsp_timer - 3000 msec
*Jun 11 09:45:14.506: //-1/xxxxxxxxxxxx/VTSP:(1/0:0):-1:-1:-1/vtsp_allocate_cdb:
CDB=0x843DBFA0
*Jun 11 09:45:14.506: //-1/xxxxxxxxxxxx/VTSP:(1/0:0):-1:-1:-1/vtsp_do_call_setup
_ind:
Event=E_TSP_SETUP_IND
Progress Indication=3, CarrierIDCode=, Info Trans Capability=128, Source Carr
ier ID=, tg_label_flag=0
*Jun 11 09:45:14.510: //-1/3C6720068410/VTSP:(1/0:0):-1:-1:-1/vtsp_timer:
Timer Start Time=13390098, Timer Value=180000(ms)
Anonymous (not verified) Mon, 05/12/2008 - 06:42
gateway attempts to match the called number of the call setup request with the configured incoming called-number of each dial peer. Because call setups always include DNIS information, it is recommended to use the incoming called-number command for inbound dial peer matching
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
