AToM ATM pvc endpoints
May 6th, 2008
At my place of employment we have been implementing AToM in order to back haul some legacy ATM network through the MPLS cloud until we can push the IP termination points to the appropriate market aggregation routers. My Question is in regards to dissimilar VPI/VCI on the xconnect endpoints, while using aal0 encapsulation. We have some xconnects that were built with different vpi/vci on two of our MPLS enabled routers. I wouldn't have thought that these xconnects would successfully pass traffic with aal0 encapsulation; however, they have been up and working for quite awhile now. There is concern within our organization that this could be a bug, and a code upgrade could render all of these non-functional. I have included sample configs to help illustrate this. I would appreciate any help understanding what may be going on here. Perhaps more importantly, determining if this is correct behavior for Cisco Routers or if we may have stumbled upon a bug.
RouterA#
interface Loopback0
description MPLS-Loopback
ip address 2.2.2.2 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-dense-mode
no clns route-cache
end
interface ATM1/0/0.84 point-to-point
description client 444
bandwidth 256
no atm enable-ilmi-trap
no snmp trap link-status
pvc 0/84 l2transport
encapsulation aal0
xconnect 1.1.1.1 444 encapsulation mpls
end
RouterB#
interface Loopback0
ip address 1.1.1.1 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
end
interface ATM2/1/1.186 point-to-point
bandwidth 256
pvc 0/186 l2transport
encapsulation aal0
xconnect 2.2.2.2 444 encapsulation mpls
end
It may also be pertinent to mention that these endpoints connect to ATM switches in each market that are configured with the respective vpi/vci for that xconnect endpoint.
(IP/Frame/CPE)-->(Frame/ATM switch)-->(MPLS/PE/xconnect)--CORE-->(MPLS/PE/xconnect)-->(ATM switch)-->(nonMPLS/IP/router)
Overall Rating: 3.5 (2 ratings)
mounir.mohamed Tue, 05/06/2008 - 03:53
  • Gold, 750 points or more
As far as i know there are no restrictions on this point, you can use different VPI/VCI on both sides in VC mode, as soon as the VCID is the same.
Even if you use MPLS cell-packing to insert multiple concatenated ATM cells in an MPLS packet.
We already implement ATM over MPLS with different VPI/VCI's on 7200 Series with different NPEs and different IOS S train versions and it's working great.
Please rate helpful posts.
Best Regards,
Mounir Mohamed
djwilliams1979 Tue, 05/06/2008 - 21:12
Thank you Mounir,
You have helped me to confirm some of my suspicions. I'm glad to hear that we are not the only ones successfully using this scenario. Incidentally, most of these xconnects exist between 7613 and 7606 routers running different IOS code. We have had cases where these types of xconnects did not work and rebulding them with matching vpi/vci seemed to have resolved the issue. This presents a different question. Perhaps we shouldn't be asking ourselves why differing VPI/VCIs worked, but why, in some cases, they don't? I would be curious to know what the order of operations is within the router logic in regard to ATMoMPLS using the AAL0 ecapsulation.
mounir.mohamed Tue, 05/06/2008 - 23:03
Well this should not happen unless there is misconfigurations or specific IOS limitations across your gears.
Look there are some limitations for MPLS AToM Implementations across different platforms and of interfaces types for specific series, for example not all SIP types support all ATOM L2VPN features, for example Cisco 7600 SIP-400 Support 4 SPA Bayes and up to 4G bandwidth with VPLS/AToM/GRE/CBWFQ/WRED, also you may configure OAM so the PVC doesn't get up because it's supported over AAL5 on 7200 and 7500 only.
Does there is any OAM configurations?
Would you provide more details about such unsuccessful test (Series / IOS / PA or SPA ...etc)?
Can you send the config with some debug commands.
R1#debug mpls l2transport vc event
Best Regards,
Mounir Mohamed
