05-06-2008 03:11 AM - edited 03-15-2019 10:27 AM
I am having problems with a T1 circuit (ESF, B8ZS and E&M Winkstart) and CallManager 4.2.
controller T1 1/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1-24 type e&m-wink-start
This is terminating on a 2621XM with a NM-HDV.
I can successfully make inbound and outbound calls depending on having the port line in on the pots dial-peer.
If I have the port line in on the pots dial-peer, I can make outbound calls but inbound calls fail. On debug of voice vtdp inout I see there is no Called number. Debug attached.
voice-port 1/0:0
translate called 1
bearer-cap Speech
dial-peer voice 9 pots
tone ringback alert-no-PI
destination-pattern 9.T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
progress_ind disconnect enable 8
fax rate disable
direct-inward-dial
forward-digits 11
port 1/0:0
If I take out the port line from the pots dial-peer inbound calls work and the deb shows the called number. But obviously the outbound doesn't work.
I dont know if the call is failing before it sends the DNIS or DNIS is the problem I dont know enough about e&m.
voice-port 1/0:0
translate called 1
bearer-cap Speech
fax rate disable
direct-inward-dial
forward-digits 11
This is the voip dial-peer
dial-peer voice 101 voip
preference 1
destination-pattern 23T
modem passthrough nse codec g711ulaw
voice-class codec 1
session target ipv4:10.3.1.14
incoming called-number .
dtmf-relay h245-alphanumeric
fax rate disable
no vad
An ideas greatly appreciated.
05-06-2008 04:03 AM
Found it it was the direct-inward-dial copied from a pri install!!
Doh
