Jagdeep Gambhir Tue, 05/06/2008 - 07:27
  • Red, 2250 points or more
Hi ,
To reset the admin password you need to console into appliance. If you don't remember console password then only option is the reset it using recovery cd,
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.1/installation/guide/solution_engine/admap.html#wp1038722
Also if you can't login to GUI after the upgrading acs to 4.1 then you need set up GUI admin via console,
To add a GUI account that the CLI administrator can use, use the add guiadmin command.
add guiadmin [admin] [password]
~JG
Do rate helpful posts
