Cat OS multiple community strings
May 6th, 2008
Is it true about Cat OS that CatOS can only support a single SNMP community string for each of the three modes (RO, RW, and RW-ALL). So if I have two RO ommunity strings it'll support only one and if so in which order? Is there any workaround?
glen.grant Tue, 05/06/2008 - 05:39
  • Purple, 4500 points or more
I believe that is correct about catos. I think it will only allow you to set one so its not possible to put 2 in , if you do another set it will just over write the current snmp password.
nawas Tue, 05/06/2008 - 05:54
Is there any doc on this? I couldn't find any on CCO ?
