Cat OS multiple community strings
May 6th, 2008
Is it true about Cat OS that CatOS can only support a single SNMP community string for each of the three modes (RO, RW, and RW-ALL). So if I have two RO ommunity strings it'll support only one and if so in which order? Is there any workaround? I'm running 8.5.2
Joe Clarke Tue, 05/06/2008 - 09:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
CatOS has support for multiple community strings in later versions. You can configure them with:
set snmp community-ext ...
For example:
set snmp community-ext notpublic read-only
nawas Wed, 05/07/2008 - 07:34
Deos 8.5.2 support multiple strings
Joe Clarke Wed, 05/07/2008 - 08:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes.
