Mutliple SSID / encryption on stand-alone1200 AP
May 6th, 2008
Hi, I want to create three SSIDs wit hthe following securuty methods on a 1200 (802.11BG) 1200 AP.
SSID 1 - no encryption
SSID 2 - 128 bit WEP
SSID 3 - WPA
IS this possible (either with or without the use of VLANs).
I know it works for LWAPP APs.
THXS
Goen
Alex Pfeil Tue, 05/06/2008 - 07:25
yes, this is possible. If you configure the ssid in the http GUI, just add each SSID in separately with different names and you should have no problem. You can also do this from the command line with a little more work, obviously.
Alex
MZydorczyk2 Tue, 05/06/2008 - 08:41
I believe you need a separate antenna for each ssid then since you want 3 encryptions. You can only put one encryption type per antenna (well dot11 interface that it).
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
