2106, adding 2nd WLAN
Answered Question
May 6th, 2008
There's a thread here somewhere which helped me get my 2106 set up with one WLAN, a guest WLAN. Now I'm trying to set up a 2nd WLAN on the same WLC. I created a new dynamic interface, WLAN, and corresponding AP group VLAN. However, the lone AP in the new WLAN is pushing out both WLANs, even though it is configured as being only in the second. I must be missing a config step here, but what?
Correct Answer by Rob Huffman about 8 years 11 months ago
Hi Jeff,
The feature you are looking for is called WLAN Override :)
Enabling WLAN Override
By default, access points transmit all defined WLANs on the controller. However, you can use the WLAN Override option to select which WLANs are transmitted and which ones are not on a per access point basis. For example, you can use WLAN override to control where in the network the guest WLAN is transmitted or you can use it to disable a specific WLAN in a certain area of the network.
From this doc;
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40wlan.html#wp1114777
Once you create a new WLAN, the WLAN > Edit page for the new WLAN appears. In this page you can define various parameters specific to this WLAN including General Policies, RADIUS Servers, Security Policies, and 802.1x Parameters.
**Check Admin Status under General Policies to enable the WLAN. If you want the AP to broadcast the SSID in its beacon frames, check Broadcast SSID.
Note: You can configure up to sixteen WLANs on the controller. The Cisco WLAN Solution can control up to sixteen WLANs for Lightweight APs. Each WLAN has a separate WLAN ID (1 through 16), a separate WLAN SSID (WLAN name), and can be assigned unique security policies. Lightweight APs broadcast all active Cisco WLAN Solution WLAN SSIDs and enforce the policies that you define for each WLAN.
From this good doc;
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665d18.shtml#c3
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Wed, 05/07/2008 - 05:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jeff,
From this doc;
From this good doc;
Hope this helps!
Rob
jeff.velten Wed, 05/07/2008 - 05:37
Exactly the answer I needed, Rob. Thanks! I was looking in the AP config and not in the radio config. No wonder I couldn't find it.
Rob Huffman Wed, 05/07/2008 - 05:55
  • Hall of Fame,
    Founding Member
Hi Jeff,
You are very welcome! Too many config areas sometimes ;-)
Take care,
Rob
