More effective ways of picking ip's from logging
May 6th, 2008
When troubleshooting firewall issues I usually run term mon, let the log run for 30 seconds and then stop it capture the output into notepad then do a find for the IP/subnet I am interested in.
This is surely not the most efficient way of doing this.
Is there a way of putting some kind of access list on the output of terminal monitor or do others log to a syslog and filter on that
I am keen to find a more efficient way of spotting a host in the logs when I am trying to troubleshoot why they can't connect to a resource.
Roger
Jon Marshall Tue, 05/06/2008 - 06:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Roger
I use the capture comnmand. Example from a pix
access-list capit permit ip host 197.12.1.2 host 212.7.1.12
capture cap access-list capit interface outside
The above would capture traffic on the outside interface from 197.12.1.2 to 212.7.1.2.
You can then do a
"sh capture" to view the results.
Attached is a link to capture command for ASA v7.2 which goes into a lot more detail.
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/c1_72.html#wp2034121
Jon
