Cisco 4006 strange error
May 6th, 2008
I have Cisco 4006 running cat OS, it has started throwing follwing error, what it tells that it is spantree issue but this switch has only 6 slot so what is the port 7/1. can someon shed some light on it?
2008 May 06 09:53:37 %SPANTREE-5-ROOTCHANGE:Root changed for Vlan 11: New root port 7/1. New Root mac address is 00-d0-ff-e8-94-0a
ankbhasi Tue, 05/06/2008 - 06:37
Hi Nawas,
Can you please confirm the CATOS version which you are running on your switch?
nawas Tue, 05/06/2008 - 06:47
mac address im seeing in the error log is from the 6506 where it is connected as a trunk/etherchannel, strange that none has blade 7 in it. Could this be referring to Portchanel interface?
