CSA SQL 2000 database move to 2005
May 6th, 2008
I've been informed that the SQL 2000 database that our MC uses (version 5.1)in one of our environments needs to be moved to a SQL 2005 database server. What's the best way to point the MC to the new SQL 2005 server?
tsteger1 Thu, 05/08/2008 - 16:18
  • Red, 2250 points or more
I don't believe 5.1 supports SQL 2005 but I could be wrong.
If you must upgrade the database, you may need to do a CSA migration to a new 5.2 MC and then migrate hosts.
I'd ask TAC if it's supported.
Tom
marcus6150 Fri, 05/09/2008 - 06:23
Thanks for the info. I found out that the SQL 2000 database can be moved to another SQL 2000 server. So, if the db is moved to a different server, will just a reinstall of the MC work to point it to the new db server. It will retain all of the policies as they are correct?
