Unity 5.0 Latest Bulk Import Tool PAGER1_TEXT_AFTER_DIAL_DIGITS
May 6th, 2008
Does anyone know what the latest Bulk Import Tool Version is? Also, how can you verify,there does not seem to be an "about" button
The reason i ask is because there is a field PAGER1_TEXT_AFTER_DIAL_DIGITS that will not bulk
Overall Rating: 4 (1 ratings)
eschulz Tue, 05/06/2008 - 08:13
This is a known issue, see CSCso68194. The next version of CUBI should have the fix. I don't know if that version has made it onto CiscoUnityTools.com yet. If not, according to the bug release notes, Cisco TAC should be able to get a fix for you.
mdury Fri, 05/09/2008 - 05:14
Like you suggested I opened a case nd received the ES41 for Unity 5.0(1)
I wanted to advise that the Bug notes have the correct syntax, but the readme/release notes included incorrect syntax
eschulz Mon, 05/12/2008 - 07:41
Thanks for the heads up. I'll try to track down where those ES readme notes come from and get them fixed. I believe the help file included with the ES also has the correct syntax. So it seems just the ES readme is wrong.
