Reg. overlapping networks for S2S VPN
May 6th, 2008
Hi all
Iam facing an overlaping nw issue while establishing a S2S VPN tunnel .Remote end is Cisco PIX Firewall ; however that is an internal PIX Firewall (with public IP) . The remote perimeter fw is Checkpoint (next hop of PIX)
My end vpn gateway is VPN Concentrator but perimeter fw is Checkpoint fw.One of the interface of my end CP Firewall is VPN Concentrator . My end VPN Conc and CP FW are connected to L2 Switch which connects to Internet router .
There is an issue when i am trying to establish VPN TUNNEL between PIX (remote gateway) and VPN Concentrator (my end).The issue is that the remote end is having the subnet and trying to access the subnet at my end ;however is present at their end also. Please let me know as to how can i configure the NATTING at my VPN Concentrator end to translate the addresses , if i want those ppl should come with different destn IP Address to access devices at my end .
The crypto acl in the VPN Conc (my end ) includes (which is a free IP) I want that remote users with IP Range should connect to this IP ( when packet will hit the VPN Conc and should get translated to
Please help as this is urgent
cisco24x7 Tue, 05/06/2008 - 11:04
On the Pix side, their network is They will be accessing
on your side that you will translate into on your side. On your side,
you will NAT the source of into when going to destination
Basically, no change on the Pix's side:
access-list nonat permit ip
access-list vpn permit ip
nat (inside) 0 access-list nonat
crypto map vpn 10 ipsec-isakmp
crypto map vpn 10 match address vpn
crypto map vpn 10 set trans 3des
crypto map vpn 10 set peer VPNC
crypto map vpn interface outside
On the concentrator, you setup NAT on concentrator for source destination You then translated the destination to and keep the source
original. It can be done with a few click on the VPNc.
Easy right?
ankurs2008 Tue, 05/06/2008 - 12:48
u have understood my issue correctly but can u tell me how to configure this at VPN Concentrator ?
