Removing community string in Cat OS
May 6th, 2008
Having hard time to remove community string in cat OS. Document says
clear snmp community will do it but i don't think it is the case
my config is as follows
set snmp community read-only mycommunity1
set snmp community read-write mycommunity2
set snmp community read-write-all mycommunity3
when i try to remove it
Cat OS switch> (enable) clear snmp ?
access Clear SNMP access table
access-list Clear SNMP access list
community Clear SNMP community table
community-ext Clear SNMP additional community string
group Clear SNMP group
ifalias Clear SNMP ifalias
notify Clear SNMP notify table
targetaddr Clear SNMP targetaddr table
targetparams Clear SNMP target parameters table
trap Clear SNMP trap receivers
user Clear SNMP user
view Clear SNMP view
Cat OS switch> (enable) clear snmp community ?
index Snmp community index keyword
Cat OS switch> (enable) clear snmp community-ext ?
<community_string> community string
Cat OS switch> (enable) clear snmp community-ext mycommunity1
Community string community1 not found. I treid with the other 2 and got the same error, anyone know what i could be doing wrong?
glen.grant Tue, 05/06/2008 - 08:34
You could try set snmp community read-only , then hit the enter key and see that clears the name
