Speed dials
May 6th, 2008
I have setup speed dial buttons for this phone. However, when I am speaking with a caller and try to conference in another person using a speed dial button, I am unable to do this? Is there a limitation with the speed dial buttons where you can't conference or transfer the call while on a call with someone?
CiscoIP7961 Wed, 05/07/2008 - 05:40
Hi Remy,
I answer a call. I press conference and then "#" and then type in "speed dial #" (ie. i have 99 speed dial numbers programmed from 11-99).
I try to conference in my caller using a speed dial but it wouldn't work.
Jaime Valencia Wed, 05/07/2008 - 14:15
  • Cisco Employee,
  • Hall of Fame,
    2011
for the numbers that are not assigned to a physical button you need to use the abbrdial softkey after entering the SP id number, that's why they don't work and that is expected
javalenc
if this helps, please rate
CiscoIP7961 Thu, 05/08/2008 - 05:40
When you are on a call with someone and hit the conference button, the system menu does not show the option for the abbrdial softkey?
Jaime Valencia Thu, 05/08/2008 - 06:42
  • Cisco Employee,
  • Hall of Fame,
    2011
no, you cannot configure the abbrdial softkey on that call state
javalenc
