SCABB - Problem with Updating CM
smahbub Mon, 05/12/2008 - 05:50
The CM May not be processing and inserting RDR's into the DB, and all RDR's are being
deleted before written to the DB.Something is using a lot of your port 4100 connections
Please go through this checklist and check if these
have been done:
1.RDR-Formatter destination is not configured on the SCE (to point to the CM)
2.No policy apply operation was made after RDR-Formatter destination was first set.
3.FW prevents policy update from the SCA-BB console to the CM.
4.DB was not installed correctly.
