05-06-2008 10:28 AM - edited 03-15-2019 10:28 AM
Our Customer had a one CallManager in Genebra and another in Brazil, I am try configure the trunk, but, the call not complete. The protocol used is MGCP. The range extension in Brazil is 1XXX at 6XXX, and Genebra 9XXX. When I do debug isdb q931 in CallManager Brazil appear the message "Cause i = 0x829c - invalid number format (incomplete number). The principle the configuration Trunk it's Ok, but, I don't know tell if configuration route pattern, route list this is OK. In this moment I have access the all equipment in the IP solution.
Thank You,
Wilson
Thank You
Solved! Go to Solution.
05-07-2008 01:43 AM
Hi Wilson, Just try to do the following configs in each of the CCM Server's.
Brazil :
1. Create a RP of 9xxx and select the ICT created as the gateway. If there are multiple servers then there will be multiple ICT's created. In that case create a RL with all the ICT's and select that ICT in the RP.
Do just the opposite RP's in Genebra. Those will be 1xxx & 6xxx.
Rate the solution if this works.
Thanks.
05-06-2008 10:34 AM
is the incoming CSS on the GW able to reach the phones??
javalenc
if this helps, please rate
05-07-2008 04:30 AM
Hi Javalenc,
I believe that yes, but, who I can me certificate?
Thank
05-07-2008 01:43 AM
Brazil :
Thanks.
05-07-2008 04:16 AM
Hi Kolka,
I am sorry, what is the significate ICT?
Thank You,
Wilson
