05-06-2008 10:33 AM - edited 03-15-2019 10:28 AM
Has anyone ever configured VWIC MFT 1-Port E1/T1, 2811 router. The router is currently installed in Mexico, and we are trying to connect to PSTN. The provider is Telmex. The gateway is configured via MGCP.
Here is a part of the config:
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
interface Serial0/0/0:15
no ip address
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/0/0:15
cptone MX
Here is the output of the debug isdn q921
*May 6 20:30:01 CET: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
*May 6 20:30:01 CET: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*May 6 20:30:02 CET: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*May 6 20:30:03 CET: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*May 6 20:30:04 CET: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*May 6 20:30:11 CET: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
The output of show controllers e1:
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20060707, FPGA: 13, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (97 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 1 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
1 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
The tei esthablisment in not been done. Telco says they received a Multiframe-error.
Thanks a lot.
05-06-2008 11:17 AM
Did you verify w/telco the correct ISDN switch-type to use, as well as the correct framing and linecode settings?
05-06-2008 12:09 PM
The framing and linecode settings are correct NO-CRC and HDB3 the onlything about ISDN type is that the telco gives a strange answer about that. The only thing is that the voice gateway is connected via an CAB-E1-RJ45BNC= to the Telmex equipment. On Cisco I have read about a R2 connection in Mexico but I don't know if this is for voice calls.
05-06-2008 12:21 PM
Try playing with the changing the ISDN switch type, make sure they match in the call manager and the gateway. However, Im not too familiar with R2 signaling, as I am here in the US, but I do know that you should check with your telco to get the exact settings you need to configure. example configuration
ds0-group 0 timeslots 1-31 type [line-signaling-type] [interregister-signaling-type] ani service mgcp
07-22-2009 02:17 PM
Hi, R2 is also for voice. Here is an example for the E1 controller in Mexico.
framing NO-CRC4
clock source line primary
line-termination 75-ohm
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
unused-abcd 0 1 1 1
country telmex
seizure-ack-time 30
disconnect-tone
category 2
signal-end-to-end
answer-signal group-b 1
caller-digits 4
dnis-digits min 4 max 13
ani-digits min 0 max 10
dnis-complete
answer-guard-time 750
ani-timeout 10
groupa-callerid-end
If this helps pls rate
Vhilario
09-14-2016 07:14 AM
According to my researsches it is impossible to set the GW as MGCP up. Is this correct?
