Autonomous -> LWAPP Upgrade Tool & Vista
May 6th, 2008
I tried to install the v. 3.4 upgrade tool on Vista Business 64 bit. The installation fails with a pop-up titled "Severe" with error "Error in opening iput file."
The real problem I'm having is that I can't uninstall the failed installation. It shows up in the installed programs list, but upon uninstalling pops up with "Setup Initialization Error" "Setup is unable to find _SETUP.DLL, which is needed to complete the installation. Error 103."
Any advice on how I can excise this thing out of my system?
Overall Rating: 3 (1 ratings)
Toivo Thu, 05/08/2008 - 05:03
Unfortunately that didn't do the trick. I did look at the uninstall.bat file and tried running the isuninst command manually with the same options and compatibility mode, but it just immediately exists without doing anything.
dennischolmes Thu, 05/08/2008 - 05:08
Looks like a manual uninstall and a registry clean for you my friend. Good luck.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
