05-06-2008 11:44 AM - edited 03-15-2019 10:29 AM
Quick question: If a PRI has been ordered and provisioned to use ISDN protocol "NI-1" what does this correspond to when configuring the "isdn switch-type ????" command on the PRI?
Do I use "isdn switch-type primary-ni"?
TIA for any assistance
05-06-2008 12:30 PM
Hi, according to this document there is no NI-1 standard for PRI only for BRI!
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080093d6d.shtml
Might be worth checking with your telco what has been provisioned again.
If it is a PRI it may just be a typo with the 1 and you would configure isdn switch-type primary-ni
If its a BRI you would configure isdn switch-type basic-ni.
05-06-2008 12:41 PM
Thought it was odd. Thanks very much!
