host unreachable
May 6th, 2008
WAN is BGP.
and LAN is EIGRP.
the WAN iterface is reachable from
the carrier's PE router, however the
LAN port is unreachable.
I reset the LAN interface and it became reachable ffrom the carrier's PE router
but just for a while, and it became unreachable again.I did it a couple of more times and got the same result.
Where could be the possible problem?
Is there a possibility of routing issue
within the carrier's side???
Thank for the advise..
Richard Burts Tue, 05/06/2008 - 14:11
Jayson
A good place to start to try to understand this issue would be with the output of show interface for the LAN interface and perhaps the configuration of BGP and EIGRP. Could you post those?
Rick
jsheriony Tue, 05/06/2008 - 14:29
Rick,
thanks...here they are...
interface FastEthernet0/0
description
ip address 10.42.254.59 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip authentication mode eigrp 81 md5
ip authentication mode eigrp 52 md5
ip authentication key-chain eigrp 81 *******
ip authentication key-chain eigrp 52 *******
ip route-cache flow
speed 100
full-duplex
fair-queue
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:1
description **********
bandwidth 1984
ip address 172.35.0.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
load-interval 30
no cdp enable
router eigrp 52
redistribute connected metric 1000 1 255 1 1500
redistribute static
redistribute bgp 65000 metric 1000 1 255 1 1500
network 10.42.254.56 0.0.0.7
maximum-paths 2
default-metric 100000 1 255 1 1500
no auto-summary
neighbor 10.42.254.58 FastEthernet0/0
neighbor 10.42.254.60 FastEthernet0/0
neighbor 10.42.254.61 FastEthernet0/0
router bgp 65000
no synchronization
bgp router-id 172.35.0.1
bgp log-neighbor-changes
network 82.197.139.130 mask 255.255.255.255
network 172.21.175.220 mask 255.255.255.255
network 172.35.0.0 mask 255.255.255.252
redistribute eigrp 52 route-map EIGRP52_to_BGP
neighbor 172.35.0.1 remote-as 7438
no auto-summary
sundar.palaniappan Tue, 05/06/2008 - 16:41
Try this;
show ip bgp nei 172.35.0.1 advertised-routes
If you see the being advertised to the PE but from the PE they can't get to your LAN then the PE might be routing traffic via an incorrect path. You would need to get the MPLS service provider to check the routing on the PE at this point.
Sundar
