RTT for Clustering over IP between two countries in Europe
May 6th, 2008
The following is a extended ping test from server in England to a server in Netherlands: The first test is ran using 1500 byte packets. The second test is ran using the default packet size.
The RTT requirement is 80ms for Clustering over IP for Call Manager 6.1, and wants to make sure if they look okay. To me they look fine, but just want opinion from forum as well.
EAMS501M#ping
Protocol [ip]:
Target IP address: 172.16.10.35
Repeat count [5]: 100
Datagram size [100]: 1500
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]: 3
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 100, 1500-byte ICMP Echos to 156.20.147.16, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 36/44/92 ms
EAMS501M#ping
Protocol [ip]:
Repeat count [5]:
Sending 5, 100-byte ICMP Echos to 156.20.147.16, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/21/24 ms
EAMS501M#
Jaime Valencia Tue, 05/06/2008 - 13:34
  • Cisco Employee,
  • Hall of Fame,
    2011
the delay test in our docs only mentions changing the TOS to use the same QoS but both of them look fine. using the default size and the 1500 MTU looks fine, seems your QoS is configured the right way to use clustering over the WAN. =)
javalenc
if this helps, please rate
abbas.ali Tue, 05/06/2008 - 13:43
Javalenc,
Thanks ! Just to let you know that we haven't deployed Call Manager yet at the customer location, but we asked to run the ping test between the two different location in two different countries. But sites are connected via MPLS. The Call Manager Publisher and a subscriber will be deployed at the hub location which connect to MPLS via 10MB link, and the other subscriber that will be clustered over IP will be at a remote location and that remote location is connected over 2MB E1 MPLS circuit. The QOS is not configured yet, and I believe the IT folks just ran the ping tests as we told them to do so to make sure that the delay is under 80ms. Don't know how busy the MPLS circuit at the time when the pings tests were ran.
Is there any recommendation we need to take into account to fully make sure we cover the 80ms RTT in full details.
Jaime Valencia Tue, 05/06/2008 - 17:42
  • Cisco Employee,
  • Hall of Fame,
    2011
i'd say to perform the test at different times thru the day, if you do this at night with no one working it's logical to get a good RTT.
you would need to try testing this during normal working hours and specially during the busiest period. QoS should be able to get the voice packets the right priority once you configure it.
about the remote location with just 2MB MPLS remember 1.544 MB must be allocated for the ICCS, so there will be only a little BW left.
all this is in the SRND under the deployment models, i'm sure you already got the doc so i would advise to take all the considerations that are in there for this to work the proper way.
javalenc
