CSS11506 TCP window size issue
Gilles Dufour Thu, 05/08/2008 - 08:24
If this is a Layer 3 or Layer 4 rule, the CSS will not modify the window size.
If this is a Layer 5 (http or ssl terminated on the CSS), then the window size can go down if the traffic comes in too fast.
We'll need to look at your sniffer trace and config to give you a better explanation.
Gilles Dufour Thu, 05/08/2008 - 14:34
There are commands that can be used to adjust the ssl behavior like ack-delay, ssl-queue, and recently tcp buffer-share.
What's your case number ?
I can have a look at the data attached to the case.
