Turn off LEDs on AP 1240, etc
Answered Question
May 6th, 2008
Hi folks I need to turn off all the leds on the aps we have installed as they are students sleeping quarters and some students are complaing the leds are keeping thme awake does anyone know how to turn the leds off completlely either via a software command or hardware thanks
Correct Answer by rob.huffman about 8 years 8 months ago
Hi Henry,
Give this a try;
config ap led-state
To enable or disable the LED-State for an access point, use the config ap led-state command.
config ap led-state {enable | disable} {Cisco_AP | all}
Syntax Description
config
Display configurations.
ap
Advanced parameters.
led-state
Enable or disable the LED-State for an access point.
{enable | disable}
Enable or disable the access point's LED-State.
{Cisco_AP | all}
Name of a Cisco lightweight access point or all to specify all access points.
http://www.cisco.com/en/US/docs/wireless/controller/4.1/command/reference/clic1.html#wp2384867
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Tue, 05/06/2008 - 17:59
Hi Henry,
Give this a try;
config ap led-state
Syntax Description
config
ap
led-state
{enable | disable}
{Cisco_AP | all}
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
