CallManager 5.1.2 Disk Usage 100%
Hello everybody.
I have a customer with a callmanager version 5.1.2.3000-2, this callmanager shows from Operating System Administration its disk 100% used.
The CAR gives an error, if I want to loggin, I'm not able to active all the services for CDRs.
I enclosed a capture from OS page.
Does anybody have an idea of it?
REGARDS.
ANY HELP WILL BE VERY APRECIATED
WALTER
Jaime Valencia Tue, 05/06/2008 - 17:37
  • Cisco Employee,
  • Hall of Fame,
    2011
try deleting all the traces you have using RTMT, if still no avail probably you'll need a TAC case so they can get root access and delete unused info
javalenc
if this helps, please rate
gogasca Sun, 06/01/2008 - 19:56
  • Green, 3000 points or more
when you are colecting traces you will get a delete files from server option (last screen)
You can start creating a remote account before opening a case with us
