BACD Call Transfer - transfer time
May 6th, 2008
I have a Drop through BACD running with a number of users in the hunt group.
When a user transfers a call that has come through the BACD there is a period of about 5 seconds before the transfered caller and the called phone can hear each other.
Firstly has anyone else experienced this issue, and secondly would anyone know how to change it?
Ive played around with transfer patterns and inter-digit timeouts, but that hasnt had any effect on the issue.
paolo bevilacqua Wed, 05/07/2008 - 02:50
  • Hall of Fame,
    Founding Member
Which exact IOS are you running ?
Darren Lynn Wed, 05/07/2008 - 14:44
c2800nm-spservicesk9-mz.124-15.T4.bin
subsequently, im seeing the same issue on another site thats running
c2800nm-spservicesk9-mz.124-15.T3.bin
paolo bevilacqua Wed, 05/07/2008 - 14:50
  • Hall of Fame,
    Founding Member
Hi, I routinely use 12.4(11)XJ4 and never had an issue like that. Are there consultive or direct transfers ?
Darren Lynn Wed, 05/07/2008 - 14:54
its both types.
Ive tested this on systems that dont run the BACD, and transferring is fine.
Ill run up a LAB i think with 12.4(11)XJ4 and see if i can generate the issue.
Can you think of anywhere that would introduce this delay? I thought it may have been inter-digit timeout, btu that wasnt the case. I also set specific transfer patterns, but that hasnt helped either.
paolo bevilacqua Wed, 05/07/2008 - 14:56
  • Hall of Fame,
    Founding Member
Really not sure. What phones are FW are you running ?
