PDM won't load
r-lemaster
I recently upgraded to MSIE7, and now PDM won't load. I get as far as the popup that says; "Loading PIX Device Manager. Please wait..." with the little hourglass, but it won't come up.
From the Java Console:
Java Plug-in 1.5.0_06
Using JRE version 1.5.0_06 Java HotSpot(TM) Client VM
Requesting URL: https://X.X.X.X/jploader.jar
java.security.AccessControlException: access denied (java.util.PropertyPermission java.version read)
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPropertyAccess(Unknown Source)
at java.lang.System.getProperty(Unknown Source)
at com.cisco.pdm.e.c.q(Unknown Source)
at com.cisco.pdm.e.c.h(Unknown Source)
at com.cisco.pdm.a.byte(Unknown Source)
at com.cisco.pdm.PDMApplet.start(Unknown Source)
at com.cisco.nm.util.sgz.Env.start(Env.java:37)
at com.cisco.nm.util.sgz.Loader.start(Loader.java:109)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
JORGE RODRIGUEZ
Level 10
Level 10
Install the right java-plug in version in your system for your PDM to run, telnet or console to the pix and do show version. note the pdm version you are running, I do not believe dpm can run using java plugin version 1.5 which is what you have.
pdm version 3 - see java requirements section
http://www.cisco.com/en/US/products/sw/netmgts
w/ps2032/products_data_sheet0900aecd802790ab.html
pdm version 4 - see java requirements section
http://www.cisco.com/en/US/products/sw/netmgtsw/ps2032/products_data_sheet0900aecd802854ee.html
Jorge Rodriguez
JORGE RODRIGUEZ
Level 10
Level 10
Jorge Rodriguez
That was it. I am running PDM 3 and Java 1.5. Once I removed 1.5, 1.4 was still there and I can now log in to PDM again. Thanks!
Glad it worked out and thank you for the rating.
Bst Rgds
Jorge
Jorge Rodriguez
